kerry4951
Jul 16, 2014Explorer
I had the rear torklift tie downs that slipped into the factory hitch. After I upgraded to a Reese Titan hitch I used the same tie downs, but had them shortened and a steel plate welded on the end. I then bolted them to the side of the Titan hitch. Maybe you can use your rear hitch as a mounting point and not the frame. Now you just have to come up with something for the fronts.
44,068 PostsLatest Activity: Jun 21, 2026
