travelnutz
Jul 16, 2014Explorer II
There isn't a canned blamket answer to your question. It depends on if any welding is done in a stress area or in an area not subject to high stresses. Also on how the welding is done and as some welders will burn literally thru and/or leave thinned areas or even a large area while others will lay layered beads of weld and allow to cool down between layers. Some welders welds look like bird droppings and others have fine fillet beads of structural welds.
Is there a reason a tie down made to fit bracket that can't be bolted to holes drilled thru the frame in a non-stressed area or by using some holes already in the frame? I don't have a problem welding to the frame as I know where the non-stressed areas are and I know how to weld correctly to a frame. All welding could be done on the brackets and then securely bolted to the frame.
44,068 PostsLatest Activity: Jun 21, 2026
