JSSEC
Jul 16, 2014Explorer
I have cut and welded many truck frame rails to lengthen or shorten wheel base from 1 ton trucks to semi triple frame rails. Personally I would not weld any thing to frame rails but drill and bolt to side of frame only don't drill additional holes in top or bottom flange.
If you do decide to weld to frame rail read this first from
Ford Truck Body Builder Advisory .
F250-550 Instrument Cluster failures have been report
ed following plasma cutting or electric welding
operations. The F250-550 Instrument Cluster circuitry has proven to be more sensitive to induced voltage. This includes service
trucks intended as mobile arc welding platforms.
Recommendations:
Perform the following operations prior to any
plasma cutting/welding operations on new vehicles.
Following completion of the plasma cutting/electric welding operations, reconnect all disconnected
units in reverse order.
1. Turn the ignition switch to the OFF position
and remove the key from the ignition switch.
2. Disconnect all battery cables from all batteries.
3. Disconnect all three connectors from
the Powertrain Control Module.
4. Disconnect the ABS Module connector.
5. Disconnect the fuel tank connector or connecto
rs (dual tanks) from the fuel sender on the
fuel tank.
6. Disconnect both Instrument
Cluster connectors.
Do not download information from the Instrument Cluster for welding protection disconnection only.
Recommendations:
fuel tank.
Cluster connectors.
44,068 PostsLatest Activity: Jun 21, 2026
