wintersun
Jul 16, 2014Explorer II
For truck frames a commercial DC arc welder will work in terms of generating a deep enough weld to hold together. If you have welded truck frames for a living then go for it. But a 1/2" Grade 5 bolt is strong enough and provides for removal of the tie-downs later by you or the next owner.
The tie-downs each only need to resist 300 lbs. of pulling force from the camper. Having the turnbuckles tighter than that and the anchor plates start to pull out of most campers.
44,068 PostsLatest Activity: Jun 21, 2026
