DGOYLER's avatar
DGOYLER
IS MY JEEP SAFE TO TOW A CAMPER????
We own a Jeep Grand Cherokee Overland 4x2 3.7L V6. It is rated to tow 6,200lbs. We are looking to purchase a camper with a "loaded" weight of 6,090lbs or a dry weight of 4,590. They say for our Jeep towing anything over 3,500lbs requires a weight distributing hitch. What is that? Is this going to be safe? Does this truly have enough power to do the job?
  • example. my 04 Ram 1500 3.7L v6..2 wheel drive. with a manual transmission. had a towing of 3,300 pounds.. same engines as yours.
    my trailer was 3,000 pounds empty. that engine worked Real Hard on the smallest of hills. WV,V,Tenn. 4,500 rpms and 45 mph... on freeways. with 3:55 gears.
    can it do it "YES" but will it last?????????
  • Can it do it? Technically yes, but it won't be a pleasant experience. The small tow vehicle and lack of power will be very noticeable.
    Go somewhere like etrailer and search for weight distribution hitches. In brief, they take weight from the rear axle and apply it to the front axle. The Equal-i-zer brand is popular.
    Keep in mind that passengers and gear in the tow vehicle should be subtracted from the tow rating.
