MFL
Feb 15, 2017Nomad II
rctoyguy wrote:
since these numbers are so low, I don't know that it would matter. I knew I wouldn't be able to just have my pick of any 5th wheel (weight wise) - but I REALLY figured I'd be safe with anything under about 11-12k.
I would say you are figuring right. If your FW loaded weight is under 12K, you would be well under RAWR/tire max rating. Worst case, you may need air bags to level the load, but a little squat is good, to help your FW tow level. You will add very little wt to the front axle, where the heavy Cummins is sitting. Many diesel 25 series trucks are towing FWs, that put them over their class GVWR.
Jerry
44,066 PostsLatest Activity: Apr 10, 2026
