JohnnyG73's avatar
JohnnyG73
Is my thermostat faulty?
I recently picked up a 27’ 1994 Starcraft. The trailer had sat for a couple of years unused. I towed it and plugged it in…everything worked great. I then moved the trailer about 10 miles to where I stored my older camper so I could transfer everything to the new one and get the old one ready to sell. Next I will get new tires and check the axles.
As soon as I plugged the trailer in the furnace fan came on. I checked the thermostat and it was in the OFF position. The thermostat has something printed on it about a time delay so I waited ½ an hour and the furnace fan was still running (I don‘t know what time delay means?). I could hear it clicking every so often, trying to ignite I assume but the tanks were closed. The temp was also turned all the way down.
I then switched the thermostat to cool to see if the furnace fan would shut off and the AC would kick on. The furnace fan did not shut off and the AC made a light buzzing/humming noise but never kicked on or blew any air. When I checked out the camper prior to purchasing, both the AC and furnace worked great. I have no idea what could have happened on the gentle 10 mile trip. I checked the breakers…OK. I lightly tapped on the thermostat and nothing changed. I unplugged the camper and waited. Upon plugging it back in I got the same results. I cannot get the furnace fan to shut off or the AC to kick in and blow air.
I’m no expert but I am leaning towards a faulty thermostat. Considering that both the furnace and AC worked when I first checked the camper out, I doubt that both of those units could have gone bad on the short trip. Is there any reason I can't replace the thermostat with a regular house style one that controls both heating and cooling?
Can anyone confirm my thoughts or offer any ideas? Thanks, John
  • Some do w/o a battery. If you have 12V lights then the converter is working.
    But no 12V could be a problem.
  • There is no battery at all. Does it need a battery? My other TT didn't need a battery unless I was boondocking. Both my new and old TT have a 12v converter to run anything that needs 12v. Is the thermostat run by 12v? Maybe I should check the converter to make sure it's working?
  • The only way to stop the furnace fan is to unplug the shore cable.
    That suggests that the battery is disconnected or bad.
    Check the battery voltage and have it load tested.
  • It doesn't matter what position the selector is in, the furnace fan always runs. The only way to stop the furnace fan is to unplug the shore cable. I will try taking the thermostat off the wall and disconnect the wires and plug the TT back in and see what happens.
  • You might check, some thermostats have a fan “auto” or “on” selector. Make sure it is not in the “on” position, or it will be always on.
    No problem. Lots of us have done it.
  • Disconnect furnace wire at the thermostat. If furnace shuts down or doesn't run immediately, connect the two furnace wires together. Furnace should start and produce heat shortly. Separate the two wires and the furnace should stop producing heat and shut down in 15-30 seconds.
    If the furnace doesn't, then it could be problem in the furnace.
    Report back after testing.
