boshog wrote:
You can get a SRW RAM 3500, 4x4, CC 6'4" box with 4,500 pounds of payload, more than enough for a 3,000 pound pin weight. The OP clearly stated they want to avoid a dually, so did I, and I don't have any issues pulling my 41 foot Montana with my SRW 3500.
4,500 pounds of payload and being about to handle pin weight are two different things. Pin weight goes almost all of the rear axle. With a SB and the desire to have a manual slider ate 270 pounds of rear axle capacity. A couple bed boxes and some stuff eat a couple hundred pounds more.
I am speaking from real life experiences with a new 2015 3500 4x4 CC SB Aisin truck purchased in September 2015. I have weighed numerous times working towards the sell of the Cardinal and the Bighorn 3575el(39'3") we just purchase. It has a 16K GVWR and was listed by the manufacturer as having a 2435 dry pin weight. We figure if we do not load the heck out of it we will be at around 3200 pin weight and under the trucks 7K RGAWR by a small amount. I would note that a 2500 would be over it's 6500 RGAWR.
For the record our truck can be pushing 8750 ready to tow.
Different trailers have different pin weight ratios. Most Montanas and Cardinals are pin heavy.
Unless one is going to tow a fairly small 5th wheel and NEVER upgrade, then go ahead and get a 2500. For everyone else the starting point should be at least a 3500 SRW and know that you are still going to have watch your loading.
Or get a dually and don't worry until you purchase a monster like Cummins12V98 has.
Note to boshog! Could you please note which model truck with a diesel weighs 1,000 less than our RAM????
11700-4500=7200 pounds. I do not think RAM makes a Diesel 4x4 CC SB that light. Maybe a Hemi Tradesman 2x4?
Our truck weighs 8220 empty, no hitch with me behind the wheel and some empty plastic garbage cans in the bed.
Chris
