ktmrfs
Sep 29, 2015Explorer III
hohenwald48 wrote:
I wonder how manufacturers come up with GVWR. It seems that if the axles are the limiting factor and you have 2 #3500 axles the GVWR would be #7000. 4 load range C tires have a total capacity of #7040. I just wonder how they come up with a GVWR of #6495 in the first place? Anybody know how that's figured?
axles aren't always the limiting factor on GVWR. they place an UPPER limit, but the frame and other construction details can also come into play.
And then looking at some brands, I believe the "1/2 ton towable" comes into play with GVWR. 10,000+ lbs GVWR which with 5200lbs axles and LRE tires is VERY possible and "1/2 ton towable" really don't play well together for advertizing.
