rastaman33609's avatar
Jan 31, 2014
Is there a correct angle for tie downs??
With my Dodge 3500, my front tie downs will be at a slight angle pulling forward. Because of the dully fenders I will have to be using a rail to move the rear tie down anchors on the TC further back, so I have the option of where to position the rear tie down.
Do I want it ...Pulling the TC forward.....Pulling straight down......or pulling the TC Back.
I am inclined to think the rear tie down should be also pulling forward..
btw my TC is 8' in an 8' bed with no rear overhang
thanks
  • this is what Torklift says about it in their installation instructions.
    "Your TorkLift tiedown inserts have offset
    triangular brackets to increase the angle of pull. These are designed to be
    used in the front facing forward, and the rear facing rearward but can be
    used in either front or rear. These recommendations are to be considered
    and followed as a basic rule of thumb. Obviously there will be some applications
    where this may not be possible. At a minimum, if opposite pull of
    both front and rear tiedowns cannot be achieved for whatever reason, you
    should have at least a forward pull at the front or rear location."
  • rastaman33609 wrote:
    at the risk of sounding stupid...what would be the difference with rear pulling back front pulling forward. the reason I ask is that with my set up it may be difficult to get the front pulling backward
    I was wrong.
  • at the risk of sounding stupid...what would be the difference with rear pulling back front pulling forward. the reason I ask is that with my set up it may be difficult to get the front pulling backward
  • Rear pulling rearward. Front pulling forward.
    Edited: Because I was wrong.
