- CAJWExplorerMy 2013 LWB bed crown measured 3/16" with a 6' level, if that helps you.
- MORSNOWNavigator III
diver57 wrote:
any idea how much the crown would be .
I think i will try the cut away idea
thanks
Get a 4' level or longer and lay it on the floor of your box and you'll see how much of a crown there is. I was surprised at how much it was on my 6-1/2' box even though I couldn't see it just by looking at it. I didn't measure it but I'm sure it's a good 1/4". - diver57Explorerany idea how much the crown would be .
thanks - SoCalDesertRid1Explorer II
Bob B wrote:
Now that right there, sounds like a great idea. :)
Use the tractor supply horse mat and cut away the center and just leave around the perimeter.......That's what I just did to mine. - Bob__BExplorerUse the tractor supply horse mat and cut away the center and just leave around the perimeter.......That's what I just did to mine.
- VinsilExplorer
Jim&Carolyn wrote:
geoboy wrote:
Is your truck a DRW?
No, but the camper is suppose to be made for a 3/4 ton short bed truck and I don't think you can even buy a DRW for a short bed truck.
Ram builds one.
DRW is not the issue. - SoCalDesertRid1Explorer III think the only camper manufacturer that recommends use of the cabover struts is Lance. Other brands may not be constructed such that you want the cabover section to be part of the truck suspension...
- diver57Explorerwhat about the shocks the use see attached to the bottom of cab over and then to the hood do you think that would work
- GeoBoyExplorer
The AF 811 is a heavy camper, maybe adding 19.5 tires and a sway bar may help your porpoising problem. Is the camper center of gravity at or in front of the rear axle? - Jim_CarolynExplorer
44,054 PostsLatest Activity: Aug 13, 2015
