rhagfo
Aug 21, 2019Explorer III
cougar28 wrote:
First thing make sure something hasn't got caught under the slide. I heard that sometimes thing fall during travel and slide or get kicked under the slide with it in and cause problems.If you don't find anything there get underneath the camper and have someone put out the slide and watch the mechanism and see if you can tell where the problem is.Wouldn't be a bad time lube while you there if that hasn't been done in a while.
X2 to this.
I check all around slides before extending, stuff falls and get caught under neath,
I really do enjoy the extra 50 sq. ft of living space, and the 11' wide living and dining room space.
You want to use Dry Lube on the slide hardware.
