kennyd63's avatar
kennyd63
Is there something wrong here?
On my last trip when I was opening the slide I noticed and heard the slide shake, make loud noise as if was to fall apart. And just now I try to open it, again and the same issue. Please advice if all it needs is grease, oil or service?
Thank you all for your help... :h
  • midnightsadie wrote:
    well I won,t own a slide,no need, but I think there suppose to go in out easy, lube and adjustments are needed. if you can,t do the work? call a local rv tech ,not the dealer, tech will come to you ,
    X2!
    Needs fixed, should slide in/out easily without making odd noises..
    I purposely avoid slides for this reason.
    You WILL need to either diagnose and fix it yourself or find a dealer to work on it..
    Now, where are all of those folks on this forum who claim slides never break?
    Perhaps they would be willing to come to you and fix it for free..
  • well I won,t own a slide,no need, but I think there suppose to go in out easy, lube and adjustments are needed. if you can,t do the work? call a local rv tech ,not the dealer, tech will come to you ,
