SouthpawHD's avatar
SouthpawHD
Is This a Travel Trailer or Park Model? - Salem 36BHBS
Eyeing a 2014 Salem 36BHBS trailer that appears to be priced well below market value. Appears to be a TT, yet has a sliding door, perhaps making it more of a park model trailer.
If I purchased this, it would be used as a TT, as we like to roam about in the summer time. My truck can pull it no problem.
Anyone have any experience with something like this?
Also, any thoughts as to the quality of Salem trailers?
Thank you.
  • Good information, thanks!!
    Yes, it does have holding tanks, which is a good thing!
    And my payload is just under 3k, so I should be good in that department.
  • I would consider that TT a Park Model. I did a bit of internet searching and it does have holding tanks. A true "Park Model" will not have holding tanks, and the toilet will be a residential toilet and plumbing is directly to a sewer.
    Your Salem has an RV toilet, and holding tanks, so I think I would call this a "cross-over park model!" :)
    From my experiences, the difference between park models and an Travel Trailer:
    Park Model has:
    Sliding patio door
    Residential refrigerator
    Residential style toilet
    No holding tanks
    Real furniture (or stand alone furniture ... not built in ... like Dinettes).
    Your's has a mix of both, basically a regular Travel Trailer with the Sliding door. I would still put this with "Park Model" though.
    Salem is a good brand of camper. It's not a "top of the line" camper that a movie star would ever own, but Salem's are good, (Mid-range / mid-grade), depending upon the model style).
  • I believe they call those park trailers. Still a TT but made to be parked in one spot. The only thing to consider is the CCC! Some have a very low CCC because they weren't meant to be towed all over loaded up.
    The next step up from my trailer when I bought was a park trailer and its CCC was I think 450lbs! Not much there.
    I just looked yours up. It has a 3k lb CCC. So it seems well suited for towing. I did notice it only shows a dry TW of 720lbs and a dry weight of 7900 lbs. make sure you load it heavy up front to get it back to a 12% TW.
  • Forest River calls it a TT but it sure is big and will limit where you can go. Your truck and trailer will be almost 60' together.
