tonymull
Apr 23, 2015Explorer
If you are drawing the same amps as before, and fuses will make sure you are not exceeding this, then you should be fine. Without the same size fuses as your old converter you could plug in an appliance(s) that draws 25 amps when your wiring is designed for 15 and overheat the wires, but if your fuse will blow when you pass 15 amps on that circut then no.
