riven1950's avatar
riven1950
Is this normal?
I had a tire go down due to a screw it it. In the process of jacking up the TT and changing the tire I took a look at my axles.
TT is a 2017 Apex and has Lippert Axles I think.
I noticed both axles have a slight crown in them. At least thats the way they look to me. I noticed it on one axle and then checked out the other one and noticed both at least appear to have a slight crown. Both appear the same, in other words crown is in same location on both axles.
Never noticed this before. Is this normal for a TT axle? Guess I could call Coachmen or Lippert but thought someone here could answer the question.
We have put about 6,000 miles on the TT and it tows great. Tire wear is normal.
  • slight crown is perfect,if they flatten out tnen you will wear tire on the inside...
  • Why jack it? Ramp is far easier. Mine is home made from 2x6s.
  • That is how they are aligned. Perfectly normal. BTW hope you jacked right under the spring perch?
  • Crown is normal as in axle bowes up in the middle.
