Mark_Kovalsky
Oct 18, 2014Explorer
majorgator wrote:
Where does your Edge Tuner get its trans temp reading from? Unless there is a hard wire going from to a sensor on the side of the tranny, then it may be getting some sort of reading from the PCM, and I don't know how accurate that could be.
I do know how accurate that is. It is the most accurate reading of internal transmission temperature you can get. The PCM has a very accurate sensor on the solenoid body inside the transmission.
