PUCampin
Oct 21, 2014Explorer
buddyIam wrote:
Pucamping,
I'll have to let my nephew know about this. He had his 99 4x4 transmission refit after having the blow out problems. Everything seems fine now but are you saying some trucks only had the oil to air.
His is a 99 ford 4x4 srw one ton
Yes, some trucks only have the oil/air cooler and not the radiator loop. It was only 1999-2000 Super Duty and 2000 Excursions built between 1/5/98 and 2/6/2000, then they reverted back to using both coolers. There was a TSB issued TSB 00-24-4 where the owner could get a newer radiator installed WITH the loop, but it was up to the owner to hear about it and bring it in. If you do not have the oil/water loop, it is a good idea to replace the radiator with one that has it. A popular mod also is to use the oil/air cooler from a 6.0 in place of the stock oil/air cooler.
