blt2ski
Mar 28, 2020Moderator
Having been looking at a replacement myself, IF you can swing it.....the gas versions from 2014 on seem to have better HP/torque specs in general. ALong with better mpg's. For 25/35 series trucks, not as much mpg....but 15 series a 20-30% improvement in most brands and models. They still got the power boost of upwards of 30% depending upon brand etc.
Example, I've been looking for and at GM 1500 dual cabs with the 4.3 V6. 2013 and before, 4 sp trans, and 220'ish hp/torque motor. 14+ is a 6 sp trans, 285/305 hp torque spec abd about a +4 mpg gain across the spectrum.
With that said, the years you are looking at, the diesels will have better performance overall. For the miles you are driving.....I have to be honest, not sure you will EVER get the initial cost back of the upfront costs. Yes you do get some back at the end. But depending upon how long of time frame, how many miles you drive......How many factors in the which fuel to use vs the other you want to throw into the equation.....
WIth the above said. Find the best priced, nicest, your spouse likes, fits your buts seats you can find, buy it! and enjoy the drive to and from. Yes a lower powered rig might take you a few hours more. I will assume you are retired, most do not seem to mind the extra time here and there.
as others have mentioned, glad neither of you are hurt!
Marty
Marty
44,026 PostsLatest Activity: Mar 03, 2025
