SlothHorn
Aug 16, 2020Explorer
I've almost got this towing thing down. One more ?
I know that dry weight is the weight off the assembly line.
I know that GVWR is a better # to look at because it takes everything, that has weight/mass, into account.
What weights are generally added between the assembly line and the RV lot? I guess I'm asking, what would I need to account for before I add my own stuff. I'm assuming the frame of the bed would be accounted for, but the mattress, for example, would be additional on top of the dry.
I had started a thread a few weeks ago in which the general consensus was that my truck could safely pull anywhere from 6,500 - 7,500 completely loaded. Wife and I found several RVs that we liked that had dry weights well within range but the GVWR was pushing it. We made a list of every, single thing we thought we might be adding to the weight and aren't coming anywhere near the GVWR on our end; however, I need to make sure I account for any weight added post-assembly / pre-us.
For reference, here's the #'s I got from my original thread...
1,650:
-subtract driver and passenger weight (we'll say 400 for this example, you adjust).
-Subtract weight of the WD hitch (app. 100 pounds)
-Subtract weight of all gear, snacks, games, beverages in the cab (we'll say 50 pounds)
-Subtract tools, bikes, wood, grills, etc. in the bed (we'll say 100 pounds).
This would leave you with 1,000 pounds available for tongue weight. Assuming your hitch is rated to handle that tongue weight, you could handle somewhere around 7,500 pounds LOADED. I would suggest, based on that, you'd need to be looking at something under 6,500 pounds dry, if not closer to 6,000 even.
