easycamper wrote:
As far as I know, only Toyota and Ford currently apply the SAE J2807 standard to rate towing capacity of vehicles that aren’t trucks.
What do you think? Can we believe these numbers? I would like to think so, since the standard is being used.
I’ll take the current Ford Escape as an example. The earlier generations of the Escape were, I believe, generally considered less capable as an RV tow vehicle than their 3500-lb rating suggested. The 2013-14 model with the 2.0L EcoBoost engine is rated at 3500 lbs using J2807.
I have a Tundra and don't even know what SAE J2807 is. I just look at the payload rating, gross rear axle rating, GCWR, etc, and take it from their. "Tow Ratings" are meaningless to me.
