SCVJeff wrote:
I did an Apples to Apples comparison Jack to Batwing, with and without the Wingman. I'm on an iphone otherwise I'd post the link, but someone posted it around the beginning of this thread. Check it out and you'll see why I keep saying that.
Okay, I read
your comparison and the synopsis that jumped out at me is as follows:
SCVJeff on RVNet wrote:
"...a shoot-out with my existing Winegard Batwing antenna with the Wingman add-on. This is the Jack replacement head that is a direct replacement on the Winegard mast.
This is a known good batwing antenna used here. So depending on the age and condition of your Batwing, and whether or not it has a Wingman attached, there may be significant differences compared to these tests.
on VHF, the Batwing clearly shines over Jack. There are too many VHF stations across the country to ignore this. The other thing that bothers me is the way that the other carriers decay when rotating the Jack. They appear to not be linear...
Some keep bringing up the point that the Jack is "easier to point"... Essentially the same.
on UHF there is close to a 6db difference between the two antennas."
Thanks for that comprehensive study. This is the setup I have (as shown on my old 2010 RV with pristine antenna and Wingman):
All I can say is this - when I have been out the last few times (in my 2014 RV with even more pristine antenna and Wingman :)) I noticed that I can only get maybe 1 channel when I was supposed to get maybe 5 or 6 (according to TV Antenna Helper app). These experiences were in State Parks here in Texas and the lots were pretty open so trees were not really an issue.
So there are improvements to be made. I don't have time or inclination to analyze the technical reasons why this is the case (but am appreciative of the work you did!) - I just want to see improvement in the number of channels I can watch. The replacement head cost me $34 + S&H so I figure things can only get better.
I will be sure to report back here what my testing bears. :)
