DanLevitan
Apr 11, 2022Explorer
Jack Failure Disaster
I had a terrible experience yesterday when I tried to unload my camper which resulted in my camper falling over on its side in my front yard. It happened so fast I'm not exactly sure where it went wrong. I'm new to truck camper loading and unloading and have only done it three times before so my experience level is likely a contributing factor but hope to get input so I can never have another jack disaster.
Shortly after I drove my truck out from under my camper and began lowering it things start going literally sideways. I have manual crank corner mounted jacks and use my cordless to lower in about two inch increments rotating to each jack. I think I was on my second rotation around the camper when I noticed the camper was twisting on the jacks. When the right rear foot was behind the camper rather than beside it I new things were different than my previous attempts. I was able to kick the foot back towards the side but that only amplified the twist on the other jacks. I went back to the previous jack and went up some thinking I could undo whatever influence I was causing but I saw the mount beginning to peel off the camper. At this point I knew it was a lost cause and had to bail out as the jacks on the other side folded under and the camper dropped. It took a visit from a recovery company to upright it to it's current legless resting spot in my front lawn. Thank goodness I don't have an HOA because it's not going anywhere fast. The damage was actually less than expected but still several weekends worth. I have spent the last year and a half going through this camper from top to bottom including removing most of the skin and replacing lots and lots of rotten wood. It made my heart ache to see it on the ground.
A little background. This camper originally used three wing mounted tripod jacks to do the heavy lifting. Some models had a fancy Safe-T-Jack system but this one didn't. Only two of the original rusty jacks and one mounting bracket remained when I took possession. The others had rotted away and were lost. During the rebuild of structure I decided to beef up the corners to accommodate four Reico Titan manual corner jacks. I remember being reluctant when the new jack mounts came with wood screws but I decided to trust the process and that's what I used. No though bolts. Possibly corners mounts were not as strong as they should have been.
Other possible factors. Last week I upgraded the water tank from a 10 gallon to a 27 gallon. I had filled it up for a leak check. I didn't think to empty the tank prior to unloading the camper so it weighed a good 230 pounds heavier than prior attempts. I haven't yet weighed this camper but I guess its 3000ish.
The hard pack ground where I was unloading the camper was nearly level, but not exactly level. It was not windy.
Maybe this was a combination of factors but I'm reaching out so I can try and learn as much as possible for next time.
