bobndot
May 17, 2018Explorer III
myredracer wrote:bobndot wrote:
myredracer, will that 'Trailer-aid' work on a leaf spring axle ?
Someone advised me it was for torsion axles . If it works on a leaf spring, then I will get one unless the Anderson 3604 leveler will work, I have one of those but have never used it.
Bob, some say no and some have had no problem with leaf springs. Have read that it can depend on how heavily loaded a trailer is. Putting a layer of lego leveling blocks under might do the trick if needed? Some have used just leveling blocks to make a ramp. An Anderson leveler would get the side up but how would you chock the TT to prevent it from rolling? Have it hooked up to the TV?
I just came across this odd looking device...
Yes , I would leave it hooked up. I think I will try it and see . Tnx for the reply .
44,066 PostsLatest Activity: May 13, 2026
