Terryallan wrote:
badsix wrote:
THANKS everyone, I'll be getting a Trailer Aid soon. I didn't know anything like that was available. I need to get out a little more.
Jay D.
Before you do. Check out your TT suspension. Raising the good tire does not always work. Many TT have floating axles, My first one did. You could not raise one tire with the other, unless you raised it 2 feet or so. not practical. Especially if you have the spread axles.
I used a jack on the spring mount at the wheel. Never use a jack out on the axle. You could bend it,
good point, that was my thoughts when I asked the question. my T/T looks like the same set up as my car trailer. but the only time I used the block on my car trailer was empty, so there wasn't much weight. the T/T is a little different in the weight dept.
thanks Jay D.
