campthewestcoas
May 05, 2016Explorer
I have always had 6 gallon water heaters but I always modified them . Being a plumber it was easy. I changed the thermostats to heat the water to 140 degrees and installed a thermostatic mixing valve at the back of the water tank to mix in cold water set at 110 degrees which this set up gives me 10 gallons of hot water
44,068 PostsLatest Activity: Jun 10, 2026
