Gaffer222
Oct 06, 2013Explorer
Chuck_S wrote:
The battery must be disconnected between camping trips. A switch on the ground (negative) cable is the most effective.
Well maintained batteries should last many years. Leaving the trailer connected to shore power should maintain battery charge but can also "boil" the battery dry. Periodic checks of the electrolyte lever should be made. Remember dry plates are dead plates.
-- Chuck
You do not have to disco your batteries between trips, as Chuck states, if you are connected to shore power with a 3 stage charger in the convertor. Most convertors now have 3 stage chargers and will not "BOIL" the battery dry. I have been leaving my original batteries, since 2005, connected to shore power and they are still going strong. I have added a little distilled water a few times in the past 8 years.
44,027 PostsLatest Activity: Mar 05, 2025
