Gaffer222
Oct 06, 2013Explorer
tsduke03 wrote:
I opened the caps on the battery and the water was up to the bottom of each of the 6 holes in the plastic cover.
I don't disconnect my battery between trips. I plug it in between trips and keep the fridge running rather than move stuff in and out of the house.
Did you look for the breaker?? You can test it by disco from shore power and have a good battery connected and test the for ~ 12 volts from each terminal on the breaker to ground. If you have 12 volts on the battery side and not the other side it is tripped or fried. You can also test the resistance between the terminals with no battery connected with an OHM meter.
44,027 PostsLatest Activity: Mar 05, 2025
