bobndot wrote:
x3.
 If you feel the need for a little less weight in the same model TT, choose aluminum over Filon. Save hundreds of lbs.
I went back to stick and tin. Our previous 5th wheel started to delaminate in the rear at 10 years old. Major repair to fix. My cousin's 1987 stick and tin Wanderer got some soft wood in the rear. He took it apart, replaced the bad wood, put it back together and resealed the seems. It too was a bit of work but nothing had to be ordered like an entire wall with the smooth sides.
