flytime
May 21, 2013Explorer
Update...I plugged my shoreline into the garage...then took a house lamp and plugged it into the wall plug outlet in the trailer. The lamp turned on. I then rechecked the breaker switch in the converte and the fuses in the converter and all looked well. Reset my GFI switch in the trailer but still no fans, trailer lights turned on. Can it be the converter itself? The trailer is a 2004 model very little use. Is it hard to change the converter, "Elixer" model. How much are they if I have to replace?
