speerstra's avatar
speerstra
Jayco Feather Floor - Spend $ or not
All,
Bought 2008 Jayco Jay Feather 218 new in 2009. Recently noticed a 1.5' x 1' soft spot on the floor near the rear window. May have been around a while as spot usually has clothes container there.
Inspected plumbing / wall / exterior. Found nothing. Dealer took a look. Plumbing is sound and says it is water damage. They also indicate there is a small spot near the sink that I had not noticed.
Dealer says it will take 8 hours just to determine cause of leak. Floor repair adds to this.
Roof / windows resealed last year. Used to have problems with AC leaking onto floor until I started blowing out the weep holes. Wonder if either of these could have resolved the leak
Don't have the time to fix myself. Debate is spend $$ or not. Have a seasonal now so could just leave it there until the floor is toast.
Any words of wisdom?
Thanks
  • You could half ass repair it. Just put down some wood laminate flooring over the rotten floor.
  • westend wrote:
    I'd suggest to get a couple of additional quotes on the work. Look for a local handyman or carpenter instead of an RV dealer.
    X2 if you can't work on it yourself. These things aren't all that complicated to work on.
  • I'd suggest to get a couple of additional quotes on the work. Look for a local handyman or carpenter instead of an RV dealer.
  • 8 HOURS to find cause of leak ??!!!!! Find you another RV repairman!!!
  • if leak is/are fixed, just put in a plywood floor on top of the current one, pieced together with self stick tiles.
    bumpy
  • I would check around for a mobile rv tech that offers a lower price then a dealer. I would check there references as well. Kind of a late model TT to let rot.
