megsfolks's avatar
megsfolks
Jayco Hummingbird CCC---is this a deal breaker?
I went in tonight to work on a deal for a new Jayco Hummingbird 17RK. It has the perfect layout for us as we re-enter the RVing world after becoming empty nesters. Then a bit of snooping caused me to slow down. I thought I would check with the expert opinions here to see if I am interpretting correctly.
The sticker on the side says a cargo carrying capacity of 646# should never be exceeded. On the same sticker, it says a full tank of water will weigh 262#. We plan a lot of dry camping and this leaves only 384# of cargo left before exceeding limits. For a light weekend, this is reasonable, but for anly longer routes we may take (or if our college daughter decides to come with for a weekend!) it seems that there is little cargo carrying margin left.
What am I missing? Why would a builder as experienced as Jayco build something so close to the edge of the cargo carrying capacity?
  • Also, I'm not so sure that dinette is all that comfortable for long term sitting.
    If you are not limited by length for driveway parking etc., consider a little larger floorplan at the same time, keeping the weight down.
    If your plan is to travel for any length of time, I would want to have dual axles . I preferred a non slide floorplan (Jayflight 23RB) using aluminum skin and no slide to save weight, with a sofa, dinette and Queen island bed for increased comfort and larger holding tanks. There are a few floorplans on the market like that in the 6,000# neighborhood with a 700-750# real tongue weight.
    At 27' I don't find it any more difficult to move around (back into tight spaces) than the smaller trailers I also tow.
    Because people will buy it. That's the answer.
    It's very light. Some people like that and will take it in exchange for much less cargo capacity.
    Yes, this is a deal breaker if you're not just an overnighter type RVer. Sounds like you need a bit more. Good thing you caught it
  • Because it is a single axle short (under 20') light weight trailer....but it does come with nitrogen filled tires
