mkdeneve
Jun 12, 2018Explorer
Thanks, Spoon. I looked at this as an option too, and there is very little room to get a TV mounted on the mirror side, which is why I wanted to build an insert in the center of the opening. The cabinet offset is a big problem to make this work as is. If you remove the mirror and try to mount a TV on that side, there is a high risk of hitting the pocket doors on the bedroom side, and even worse having the slide hit the TV on the living room side. I have yet to find a TV and mount combination thin enough that I feel will fit. Even if I do find one that will fit, the swivel option will no longer work, so I wanted to do it right the first time if I could. I too decided not to pay $480 for a Jayco 32" TV, so I am trying to figure out how to make this work. Thanks for your feedback. -Mark
