mkdeneve's avatar
mkdeneve
Jayco Rotating TV Cabinet Removal
Hi,
I have a 2018 Jayco 25BH that has the rotating TV cabinet between the bedroom and living room that has the TV cubby on one side and a mirror on the other. I want to remove this cabinet completely without destroying it. Can anyone tell me how to remove this?
What I want to do is install a solid wall insert where this cabinet is, but want the ability to return it to original if I sell the camper in the future. Thanks in advance!
Mark
  • Thanks for your suggestion. What I really want to do is have 2 TVs mounted in the same area. Since the rotating cabinet is offset for 1 TV, there is not enough room to have 2 TVs mounted unless I remove the cabinet and put a wall panel in the center. If someone can tell me how to remove the cabinet without destroying it, I can take it from there. Thanks, -Mark
  • Not sure why you would want to do that, but you could just buy a piece of 1/8 Luan, cut it to for the outer dimensions of the cabinet, stain it, spray some semigloss finish on it, drill a few holes around the perimeter, and screw it to the cabinet frame on the bedroom side.
    When you go to sell/trade the TT in you can just unscrew the panel and re-insert the screws in to the panel holes left in the frame. Nice decorative screws would help the ascetics part.
