Baja937
Jan 18, 2015Explorer
For those of you Jayco owners, are the Aluminum walls as easy to keep clean looking as the Fiberglass?
I'm going to pull the trigger on a 23MBH...Most likely the Jayflight for a couple of reasons of which I'd wish Jayco would change compared to the Whitehawk...
Whitehawk's are fiberglass...Jayflight's can be had in aluminum or fiberglass...The Whitehawk has a storage compartment in the back along with one on the slide to access the under dinette storage...No biggie I guess...
2 HUGE deals though are it looks like only 20# propane tanks on the Whitehawk versus 30's on the Jayflight...Probably could put 30's on the Whitehawk easily???
The other is the Black & Gray tanks are 30's on the WH and 39 on the JF...
