rbpru wrote:
What is the max cargo limit on your truck and the loaded tongue weight of the TT. Just because you can pull it, does not mean you can carry the weight without exceedingly the max cargo or axle rating limit.
Our TT gained 1200 lbs. and 300 lbs. of tongue weight over the listed dry TT and tongue weight.
We mixed out our F-150.
Good luck
The max towing capacity of our truck is 10,300 lbs. We have sway bars and a distribution bar. We are considering an air ride system. The max load on the Jayco trailer is 9500 lbs fully loaded. There’s not much chance we will load it with that much stuff but despite that I want to consider the possibility. The unloaded weight of the Jayco trailer 8300 lbs.
