mrp116's avatar
mrp116
Jayco Water Pump Question
My wife and I took delivery of our first TT on Tuesday, a '14 Jayco White Hawk 28dsbh. During the PDI nothing was ever mentioned about a water pump. I suppose I wasn't as prepared as I should have been and didn't ask questions about one. I assumed that once you hooked up to city/CG water the system was pressurized by the water input. However, now that I have had time to think about a few things, that obviously can't be the case when dry camping with water in your fresh water tank. So, my questions are, do I have a water pump (I must)? Where is it located? When and how do I turn it on and off? I would look this up, but the unit is at the storage facility right now.
Thanks,
Mike
  • You should have a water pump and there should be a switch in the unit somewhere.
    When you hookup to city water some units have a valve you switch over (ours does) but there is a switch to turn the pump on and off
