BadBeans
Nov 12, 2014Explorer
Thanks to both of you!
Yep, I bypassed the water heater and drained it prior to this step. I also drained the fresh water tank very good, as well as, emptied my black/gray tanks.
I will close the valve to the fresh water tank before pumping in the RV anti-freeze then. However, is there water in that line from the fresh water tank to the valve I should worry could freeze? Or did it empty when I emptied my fresh water tank?
I didn't know about the city water inlet "button". Thanks for the tip on that!!
Thanks again guys!
Thanks again guys!
44,056 PostsLatest Activity: May 04, 2014
