jefe_4x4's avatar
jefe_4x4
jefe's suspension and off-road trailer update
The suspension modification is done. Today I replaced the U bolts on the rear springs. The 3 year old ones were rusting fast. And once you tighten them down the first time with that mongo torque the breaking point of the metal drops. So, the susp. is done. Some pix:
from the bottom up: axle, perch, 4" lift block, overload spring, 1/8 inch shim, new add-a-leaf, 3 stock main leaves, 1 inch block, one thick and two thin upper secondaries (aka: overloads), upper u bolt keeper/plate. The new ubolts are 16.5 inches long untrimmed. This pic is with the camper on, fuel full, propane full, no other loading.
There is now about 1/2 inch space between the Stable Loads and the secondaries. I'm hoping that when we add water, clothes, food, sundries, people (i will be hauling 5 people at the end of the trip) in the camper itself it will be enough to make the secondaries come in contact with the Stable Loads. How does it ride? I'm thinking the overall TC on ride is improved as only the main springs and the add-a-leaf are in the picture and have a good overall ride over gravel roads and pavement. I took it out for a road test and one side was bouncing up and down like a I had an air bag on that side! What's up with that? When I got home i checked the air pressure in all the tires and found the pass/rear tires was at 30 pounds. It acted like a defacto air bag! Wierd.
Aired up to full inflation, the air bag symptom went away.
This post is about getting ready for the next Mojave Road adventure next week. It seems there will be eight bodies traveling on 3 or 4 mountain bikes, 2 motorcycles, 1 Jeep Rubicon, 2 truck campers.
This is an experiment. The last time we did the road i took my trailer which i thought was up to the rigors of off-roading. Wrong, Mojave breath. The socket part of the hitch was blown open with two big cracks. So back the drawing board. From my jeep trailer days, I decided to convert this trailer into a truly off-road capable tow since mine is the support wagon. So now the trailer and truck sport a 8 ton pintle and 16 ton lunette arrangement, not that I would need that with a 350 pound metal trailer even at full load. With the 20 inch extension it follows very well around sharp curves and undulating terrain.
The resulting 2 inch lift on the rear of the truck produced a more level stance of the TC.
If anything, it might be a smidge higher in back. I don't know if that will effect handling or not:
regards, as always, jefe
  • Good Job!!
    Have fun. Take lots of pics for the rest of us!!
