Geterdone wrote:
UPDATE: There is no sound on any speaker on CD, or radio...I contacted Jensen and they said to do an ohm,and continuity check on the speakers. I can only get to the one uder the bath sink...will have to take others out of wall...If there is a short, theys said the internal amp goes into prot. mode...not allowing sound.
Not sure how to do these tasks but I will try and figure out.
As I posted before, if you are hearing static, the speakers are connected and the power amps are working. There is no need to do a continuity check. Sound, be it static or not, does not come from a disconnected speaker. Think about it.
Stop, call them back, and tell them that all the speaker connections are OK.
