CherylH
May 04, 2017Explorer
BenK wrote:
GVWR..........Gross Vehicle Weight Rating, what that vehicle is rated for...you need to provide this info, as some OEMs has over a dozen GVWR half tons. From +6K GVWR up to +7K GVWR
GAWR..........Gross Axle Weight Rating, what that axle is rated for...you need to provide this info. Most half ton's, no matter which GVWR (except for the +8K GVWR fake half ton) has GAWR's in the +4K range. Compared to bigger/higher rated 3/4 ton and up will have +5K Front GAWR and +6K Rear GAWR
MTWR..........Max Tow Weight Rating, what the TV in 'curb' condition (meaning stripper model with NO optional equipment, other than the tow option and one 150 lb driver) can tow. Plus most ratings derive their numbers using the stripper models both in TV and trailer (dry weight)
GCWR..........Gross Combined Weight Rating, what that vehicle (TV) is rated to pull/carry in total
"R" is ratings and the OP needs to make a decision whether to believe in & adhere to them, or ignore them and do whatever...but know that the manufacturer's most likely will NOT provide warranty both in fixing something and liability
Here is the generic formula for the ratings system:
GCWR >= TV + trailer + stuff
Stuff being ANYTHING loaded into and onto both the TV and trailer. Plus the WD Hitch system
Most of the items the OP has listed below are fashion statement stuff and not much to do with towing...except that they add weight to the 'curb' (stripper model) weight
EcoTec3 5.3L V8 Flex Fuel....small block that is rated to also run on a blend of corn alcohol. Note that any blend will have less power per gallon than pure high quality gasoline. Not going to win many races with this, but it is NOT a race and used that analogy to make the point for going up inclines.
6-Speed Automatic, 3.42 Rear Axle Ratio....Automatic will have a low 1st gear, but only to get it moving. 3.42 is a highway MPG diff ratio, IMHO, but that is what you have. It can be changed out later to increase the MTWR & GCWR
Heavy-Duty Rear Locking Differential....most likely the G80 locker from Eaton. Check the glove box label and it will list all options that vehicle left the factory with. Look for G80
Integrated Trailer Brake Controller....Ok, you have a trailer brake controller and for newbies best as there is less to deal with on an install...but note that ITBC is highly integrated with the rest of the other computers on the vehicle...and that if one should have issues...often takes down the other computers (I'm not a fan of ITBC's)
Trailering Package....good and a must for towing. Make sure to always initiate the Tow/Haul function whenever you are towing or hauling heavy.
I am looking at getting a Grey Wolf 26BH-GVWR W/brakes 7402-Cargo Capacity 2823....that is towards the highest limit for any half ton, but repeat that you need to provide more info and best to go out and weigh your TV axle by axle for us to truly be helpful
Thanks! I linked 2 photos
