Greene728
May 04, 2017Explorer
My Lord y'all are totally confusing this woman!
Excellent job on correcting Lwiddis too!
You are doing a great thing by looking for a good match to your truck in a RV. Nothing sucks worse than a bad towing experience and getting to your destination and being mentally exhausted from the RV driving the truck. Based on your trucks specs, I'd say be looking at something in the 20-26ft range with a max weight of maybe 6000 pounds (give or take a smidge). Anything less than this is even better. At this weight range and under, you should be fine on all weights. I will recommend one thing right out of the gate though. If the truck came with P rated tires, look very seriously at swapping them out for an LT tire that will provide a much better towing experience. If it came with LT tires then your already good to go! And when looking at RV's never use the UVW. Always use the GVWR or max weight. That is worse case scenario and anything under that is just weight to the good. Remember, you'll never tow or use your RV empty, so really it's a useless number.
Good Luck!
Good Luck!
