bjkb1f
Apr 15, 2020Explorer
hondapro wrote:
If you go with the diesel skip the 2500 and go with the 3500 the diesel engine is heaver than the gas engine. So the 2500 with the diesel will have a low payload capacity
This. 2500 gas or 3500 diesel. There are 250/2500 series diesel trucks out there with the same payload has a 1/2 ton. For only a couple thousand more, you'll end up with a much more capable truck with a 350/3500 SRW.
I haven't seen payload numbers, but maybe check out the 2020 F250 with the 7.3 if you're not sold on Ram/diesel.
