Ride_S40T
Apr 26, 2020Explorer
RickG64 wrote:
I just bought a 2020 Keystone Outback 330RL Length 37.83 ft, width 8 ft, height 11.33ft
Dry weight 8,839 lbs, payload capacity 1,661 lbs, gvwr 10,500 lbs, hitch weight 1,100 lbs
My question is how much truck am I going to need to pull this? My wife and I are considering a Ford F-250 with a 6.7L diesel or a Dodge Ram 2500. The trailer dealer suggested a Ford F-150 with the EcoBoost engine. I’ve never owned a trailer and don’t want to buy the wrong vehicle to tow it. What do you suggest?
Oh and after you make your decision, maybe contact that salesperson and let them know (in a polite way) that sage advice across the board recommend at least a 3/4 ton and probably a long bed at that to be safe. There is a specific formula for length of trailer coupled with length of wheel base. That's science, not guesswork.
That advice should come with a caveat that it would have to be something properly rated, not giving you that info is irresponsible and quite possibly dangerous. You can find 1500s that go up to and beyond 13,000 tow capacity with MAX TOW PKG but again, you need to run the numbers on hitch weight, GVWR, etc. to be sure. Your average 1500 would not be safe with that trailer, IMO.
I've been to a few RV shows where I heard some of the most outrageous claims made by very green salespeople, one had no clue at all about the equipment or safety aspects of towing. Knew zip. It was scary. Tried to help him out, to no avail.
You will not regret having the right truck, a safe truck not just something that will "pull it".
