TexasATM
Feb 18, 2014Explorer
I just installed mine this past weekend and it went really well. I had to cut the ears off the front of the WD jack mounts because they were bumping the propane plate. Instead of shimming up the propane tray, I just drilled holes in it and put the ubolts through those holes (they sit under the propane tanks, so no interference). Either way will work though.
It took me and one other guy about 3 hours to do the install. It seems daunting, but it really is very simple. I was not on level ground and haven't hitched up to it yet, so I'll probably have to do some fine tuning, but it should only take a few minutes to get all set before my next trip. I'm really looking forward to trying it out!
Question for those of you using one now - do you have any clearance problems with the WD bars? They look very low to me (I had trunion bars before)...
44,068 PostsLatest Activity: Jun 14, 2026
