93Cobra2771
Mar 03, 2014Explorer
When backing up, the head will swivel to one side or the other if you are backing up straight. If you have to change direction with your two vehicle a time or two on the way back, you will see the nose of the trailer shift to whichever side if you cut sharp enough.
I had one incidence where the foot of my tongue jack (rectangular shaped) ended up not being able to extend because I had backed up at an angle and the foot came into contact with the spring bar on the way down.
I solved that problem by not raising the foot of my jack above the spring bars. Worked just fine that way after that.
To your original question - not really any different than a normal backup other than realizing that the nose my shift one way or the other.
44,068 PostsLatest Activity: Jun 14, 2026
