Lantley
Mar 03, 2014Nomad
Ron Gratz wrote:Unyalli wrote:The "bump" is a feature of the four-bar linkage.
Is this Hensley bump only with the Hensley Arrow? There were changes made to the Propride and I have to assume they eliminated this bump you all are talking about as I never experienced it or even heard of it before.
The "bump" is experienced by users of both the Propride and the Hensley Arrow because both hitches use the same linkage.
You are much less likely to experience the "bump" if you set the trailer brake controller to make the trailer brakes lead the TV brakes.
However, even that does not guarantee you will not experience the "bump".
Ron
I agree with the above furthermore if you set your TT brakes ahead the bump is a non issue.
It is good to be aware of the bump phenomenon,how and why it occurs. However the bump is really a minor issue that gets overplayed on these forums.
44,068 PostsLatest Activity: Jun 14, 2026
