93Cobra2771
Mar 05, 2014Explorer
waynec1957 wrote:
What happens while backing up if the trailer and tow vehicle are not on the same level? Say for instance there's a dip and the wheels on the truck are setting higher than the wheels on the camper? Given how rigid everything is, will the hitch pivot up and down?
Yes, the head pivots up and down via the spring bars. When you are ready to unhook, you release tension on the spring bars until they are "sloppy loose". When you pull out the stinger, you don't touch the spring bars. This keeps the hitch head in the same position. So now, when you go back to hitch back up, the hitch head is in the exact same position for very easy hookup.
44,068 PostsLatest Activity: Jun 14, 2026
