Lantley
Mar 05, 2014Nomad
93Cobra2771 wrote:waynec1957 wrote:
What happens while backing up if the trailer and tow vehicle are not on the same level? Say for instance there's a dip and the wheels on the truck are setting higher than the wheels on the camper? Given how rigid everything is, will the hitch pivot up and down?
Yes, the head pivots up and down via the spring bars. When you are ready to unhook, you release tension on the spring bars until they are "sloppy loose". When you pull out the stinger, you don't touch the spring bars. This keeps the hitch head in the same position. So now, when you go back to hitch back up, the hitch head is in the exact same position for very easy hookup.
Yes the hitch head remains in place and you simply back and hitch in the same location as you unhitched.
On rare occasions you may run into an issue where you cannot exit the way you pulled in due to a parked car or some other obstruction that was not there.
With a ball hitch you can hitch at any angle and the ball will always drop on. However with a HA/PP once in a blue moon you may want to angle in differently than you unhitched. This can create a headache, however once you have experience you can recognize these situations and adjust accordingly.
44,068 PostsLatest Activity: Jun 14, 2026
