keymastr
Oct 09, 2014Explorer
which WD hitch do you have? Some have better sway control than others. You have enough tow capacity but may be approaching or over on weight carrying capacity of rear axle, depending on what you have in the truck besides yourself. Also you need to determine if you have enough tongue weight as that can drastically affect sway and that the trailer frame sits level or just slightly nose down when hitched up and on a level road or parking lot.
Go to a scale and do all the weights,(there should be a sticky in the towing section that will tell you how), so you know how your weight distribution is working and your tongue weight, axle weights etc.
Other than that it just may be getting used to the feelings but it will tow better if you get those things dialed in.
